It is currently Mon Aug 19, 2019 10:50 am
Post new topic Reply to topic  [ 124 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Jan 21, 2018 6:40 pm
Vehicle: 97 Wrangler, 5.7 Hemi, Rock Jock, 4.88, Arb's
Finished up the brake setup this weekend.
Cable brake works great...
Need to pick up some RV Jacks and weld the jack receivers on.
After that the frame should be ready to go to the Powder Coater.
MY ALMOST COMPLETED 5.7 HEMI TJ BUILD
http://www.pirate4x4.com/forum/jeep-har ... 2-5-l.html
PostPosted: Sun Jan 21, 2018 8:39 pm
Is that brake lever from the original trailer or aftermarket?
PostPosted: Tue Jan 23, 2018 6:27 pm
It's the original one but if you google it you can find replicas/replacements on sites like etrailer.com,
Example: https://www.etrailer.com/Accessories-an ... BUQAvD_BwE
These replicas don't look as beefy as the old WWII stuff...
This particular one was rusted to heck and took a lot of soaking and such to free it up and clean it.
Tried to keep as many original parts as possible but the more I push forward the more the original parts go by the wayside for improvements.
PostPosted: Sun Jan 28, 2018 7:19 pm
Ended up putting a round trailer jack receiver on each corner, made two from some 2inch tube I had. Now I can choose which corner(s) to put jack(s) on. I still have only 2 jacks, but pending on how it goes I may pick up two more.
Also bolted up the brackets I made for the Wrangler taillights. I am going to use some 97 Wrangler taillights I had laying around for now. If the lights end up getting destroyed down the road I may go with recessing LED's in the rear frame.
Now to set up some type of anti-sway bar that can be quick disconnected, there are several ideas I am thinking of, I'll see what happens. That will be the last step before the frame goes to the powder coater....
PostPosted: Mon Jan 29, 2018 8:06 am
:thumbsup:
PostPosted: Sun Feb 04, 2018 3:34 pm
Finished welding on the mounts for the trailer jacks and friction sway control.
Clocked the pivot bracket (made a new one) for the brake cable a little more and bulked up the bracket (Original on left, New on Right in pic below).
Sprayed some rubberized coated on the bracket for good measure.
The frame is now officially ready for the powder coater.
Now a day off work without rain would make it much easier to throw the frame in the back of the truck and get it to the powder coater.
PostPosted: Sat Mar 24, 2018 2:19 pm
Dropped the frame off at the powder coater for a semigloss black coating. Should have it back in a week or three....
I have been looking for an internal frame coater so I don't have to worry about rusting from the inside out.
Found this stuff below... It's supposed to be pretty good and adheres and incapsulates everything, rust-grease-etc....
Comes with a 12inch hose fitted with a 360 degree spray nozzle at the end to be able to fully cover the inside of the frame.
I drilled drain holes about every 24 inches on the frame so I should be able to coat the entire interior of the frame with this stuff.
Should work well?
Last edited by PacificNWestJeeper on Sun Mar 25, 2018 9:16 am, edited 2 times in total.
PostPosted: Sat Mar 24, 2018 7:45 pm
I bought something similar off amazon to coat the inside of my jeeps frame after the stretch. It sprayed out as a light oil, crept into all the lap joints and then turned into a wax. Any effort to protect inside the frame is better than no effort.
PostPosted: Sun Mar 25, 2018 7:49 am
"Any effort to protect inside the frame is better than no effort"
Exactly what I was thinking.......
PostPosted: Sun Apr 22, 2018 4:08 pm
I got the frame back from the powder coater and set up in the garage.
I started off running the wires for the Brake Lights and electric brakes, pretty straight forward.
Hung the axle and put the bump stops on - spring pad worked great to mount the bump stops onto.
I hooked up the parking brake cable to the old M416 parking brake handle and it works perfectly.
I then sprayed that internal frame coater by Eastwood, seemed to coat well. It runs out the holes like water so be very careful if you use this stuff. When it dries it reminds me of thick black nail polish, almost like a black marble..
Installed the brake light brackets and brake lights..
Picked up new toy - tube bender, waiting on die so I can make tube fenders for the trailer... * Any suggestions on how to mount to the garage floor temporarily, that way I can set it in a corner when not using it, any good ideas?
Bottom line the frame is all together.
Next - Make Tube Fenders, install on tub.
Weld 1 inch flat steel around upper lip inside tub to prevent water from blowing in to trailer.
Paint the M416 tub & lid.
Weld base mounts for telescoping rack
Touch up paint
Rhino line inside tub and lid.
Weld together rack to fit into base mounts attached to trailer.
Rooftop tent install
Batwing Canopy install
Solar Panel and battery setup
and a few more doodads..
Really want to be ready for snow wheeling and camping this coming winter.....
Last edited by PacificNWestJeeper on Sun Apr 22, 2018 4:19 pm, edited 2 times in total.
PostPosted: Sun Apr 22, 2018 4:09 pm
few more pics..
PostPosted: Mon Apr 23, 2018 5:30 am
DUDE!!! That is looking great!!
PostPosted: Mon Jun 04, 2018 7:07 pm
So I pulled the trigger and bought the ProTools 105 HD manual bender.
I got the 1 ½ 180 degree die for it to make tube fenders for the trailer.
Question:
I put the bender together and when I cycle the die arm the degree pointer lifts upward away from the bender degree plate.
at 0 degree the degree pointer is almost flat with the degree plate.
at 180 degrees the point is about ⅛ further away from the degree plate. See the pics.
I had a bigger gap at one point but I went back and ensured the top arms and bottom arms were aligned directly on top of each other which took away some of the gap.
I also took a breaker bar and tightened the heck out of the bolts. AND I made sure the degree plate is flat. And the die is sitting flat on the lightly greased bearing.
Any ideas on how to get it dead-on, or does ⅛ not matter and I will not notice it in the bends?
Thank you for any help ahead of time...
Last edited by PacificNWestJeeper on Mon Jun 04, 2018 7:11 pm, edited 1 time in total.
PostPosted: Mon Jun 04, 2018 7:11 pm
Degree plate bent slightly?
EDIT: nevermind, I see you checked for that already. Hmmm don't know then.
PostPosted: Mon Jun 04, 2018 7:12 pm
That was my first thought but No, I took it off and set it on a table (perfectly flat).
PostPosted: Sat Jun 23, 2018 7:12 pm
A little more headway made today, added a lip to the rim of the tub.
This should help prevent water/dirt/crud from entering the tub.
PostPosted: Thu Jul 05, 2018 4:21 am
Looks awesome!
PostPosted: Sun Aug 05, 2018 4:00 pm
Little more headway, put up some plastic and positioned some fans to do a little spraying today.
I had the paint from the Jeep color matched at my local auto paint supply shop.
Sprayed the base then 3 coats of clear, sure makes all the WWII/Vietnam dents and dings stand out.
It's just a trailer, i'm moving on, 24 hours to dry now.....
PostPosted: Fri Aug 24, 2018 6:48 pm
The original red paint job ended up really orange pealed due to low pressure. Turns out my water separator was clogged.
So I had to sand it down and paint it again. I did 3 coats of base and 3 coats of clear. I did not paint the very top since it will be Rhino lined.
I was able to get it mounted onto the frame. I am hoping to get a chance to make the tube fenders this weekend.
PostPosted: Mon Aug 27, 2018 4:35 pm
Made some good headway this past weekend on the tube fenders.
I used 1 1/2 120 wall DOM tube and bent the top corners to 60 degrees and the bottom corners to 90 degrees.
Need to make two cross braces/supports from 5/16 flat bar and then skirt them 1/8 thick plate.
I won't have any time to make much more headway for a while...
PostPosted: Tue Aug 28, 2018 6:13 pm
I went to Metal SuperMarket in Kent to determine what size steel I was going to use for the telescoping rack.
The trailer frame is 2 inches wide so that limits me to 2x2 for the base the rack will slide into.
The guy at MSM said 2x2 ¼ wall as the base with 1½ ⅛ wall is the best they have for making a telescoping rack.
There seems to be a lot of wiggle room which means a noisy rack down the trail.
Any better ideas using 2x2 as a base, what would fit inside of it better? Any special tubing I could order online?
I drew it out on CAD earlier today. see below...
PostPosted: Mon Sep 03, 2018 4:15 pm
I got one fender/tube mounted after work today.
The bump stop seems to be set just right for the clearance, will find out at some point, easily adjustable if I need more clearance.
I need to mount the other one this weekend, add some supports and then cut out a template for the sheetmetal...
PostPosted: Sun Sep 09, 2018 1:13 pm
I added the cross bracing to the tube fenders and had them both mounted up today.
I cut out a cardboard template to use to trace the pattern onto ⅛ plate (need to pick up some plate).
Also picked up some latches, trying to decide which ones to use. Not really crazy about any of them at this point..
PostPosted: Tue Sep 11, 2018 7:19 pm
6th time is a charm.... After purchasing 5 latches I could not decide on I pulled the trigger on some JK aftermarket hood latches.
They fit pretty snug and seem to look pretty good...
I ordered up the steel sheathing for the tube fenders, pick it up Friday and work on it this weekend.
Just another baby step completed..
PostPosted: Sat Sep 15, 2018 5:51 pm
Picked up the ⅛ plate, cut out the shape using the template, bent the plate around the tube (not easy). Tacked the plate to the tubing.
Bolted up tube fenders, and boom, fenders done.
Next up rhino lining.
Having them spray the fenders, complete inside of tub and the very top of the lid.
Should be able to get this done in the next 3-4 weeks.
Might start working on the telescoping rack till then.
PostPosted: Sat Sep 22, 2018 4:17 pm
I set up the base for the telescoping rack today using 2x2 ¼ wall.
I will weld the bases to the frame and I set up some brackets about half way up (where the black paint is missing) that it will bolt to the tub.
So next up is welding the bases of the rack to frame and weld brackets to 2x2's so it can be bolted to the tub body.
another step closer today.
PostPosted: Sun Sep 23, 2018 6:56 pm
Rack base welded, bolted, painted, boom.
The rack base is now welded to the frame. The tub can still be completely unbolted from the frame if it ever needs to be replaced, repaired, etc...
Now need a date with Rhino Linings....
PostPosted: Sat Sep 29, 2018 8:08 am
I got the solar panels I have been researching and looking at for a while.
These are one of the most efficient solar panels out there.
They are really well made and will not take up nearly any room in the trailer.
They have attachment points all around the perimeter of the panel so you can mount/hang it anywhere.
I picked up some extra connectors to be able to use the panel with other batteries/vehicle, etc..
The company has the BEST customer service I have ever had, awesome people.
https://overlandsolar.com/collections/p ... ar-charger
I now need to pick up the battery I chose below...
PostPosted: Sun Oct 07, 2018 7:34 am
Made some good headway this last week. Rhino Lining was able to spray the trailer this week.
I was able to pick up the Batwing: https://cascadiatents.com/shop/foxwing-awning/
I also picked up the Cascadia Denali Summit series tent: https://cascadiatents.com/shop/mt-denal ... it-series/
Now it is all about getting the telescoping rack done so I can mount the tent and Batwing.
PostPosted: Sun Oct 21, 2018 4:46 pm
I was able to get the rack welded up this weekend. I ran some wire through the tubing to be able to pull the wire for the lighting through, hopefully next weekend.
I started with the bar in the center and the went out 31 inches on center for the adjacent bars, which is required for the Cascadia Tent ( Denali Summit Series ).
I will cap the ends of the tubing and go with some black spray paint. I also need to figure out which struts I will go with as well.
To retract or bring down the tent I am looking at using a hand crank winch: https://www.harborfreight.com/2000-lb-c ... -5798.html
After I hit that point I will work on making brackets for the batwing... sssoooo close........
Users browsing this forum: No registered users and 1 guest
