It is currently Sun Jul 05, 2020 5:08 am
Post new topic Reply to topic  [ 150 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: 2004 LJ Build
PostPosted: Thu Sep 24, 2015 2:46 pm
What did your muffler and exhaust end up looking like?
I've got the skid sitting in my garage and I'm tired of having to move it around. I'm thinking about throwing it on, but wanted an idea of what I'd be looking like for exhaust work.
Thanks!
Ryan with an "R"
PostPosted: Thu Sep 24, 2015 3:05 pm
I ran the skid with the stock exhaust for about 6 months before I installed the lift, with the slight change in drivetrain angles the exhaust would occasionally hit the front right control arm mount.
Now that I have installed the lift I threw on a 18" round magnaflow with a stub out in front of the wheel, it is a little loud for me so I will be changing it when I get time.
PostPosted: Thu Sep 24, 2015 3:40 pm
Awesome! I can live with that for a few months. Sounds like I've got some work for this weekend! :thumbsup:
Ryan with an "R"
PostPosted: Sat Mar 26, 2016 10:55 am
Who needs V8's and Dana 60's when you can get the power of Carbon Fiber! The paint has slowly been chipping away on my Poison Spyder hood louvers. Because I wanted to be a little different I decided to wrap it in carbon fiber vinyl instead of repainting it.
There are a couple of wrinkles because the louvers where a pain but over all I like how it came out.
PostPosted: Sat Mar 26, 2016 11:46 am
Attention Whorse
Vehicle: 1993 YJ
2015 Ram 2500 6.4L
Looks cool. I was lucky enough to get a black powdercoated one when I ordered a raw one.
trophygirl wrote:
The price goes up for every penetration
PostPosted: Fri May 20, 2016 11:18 am
Welded on the Poison Spyder door skins that I got form my B-Day, I will color match them this weekend.
PostPosted: Sat May 21, 2016 12:02 pm
I installed a couple of OEM style switches for my lights, the LED on the generic switches I had were too bright and where kinda annoying.
PostPosted: Sun May 22, 2016 4:53 pm
Painted the door skins
PostPosted: Mon May 23, 2016 9:55 am
Looking good! :thumbsup:
Ryan with an "R"
PostPosted: Tue May 24, 2016 8:15 pm
Installed an new Odyssey Battery tonight, moved the old Optima battery to my trailer.
PostPosted: Tue Jun 27, 2017 8:31 am
Finally getting around to installing the Alloy shafts and my rear locker. Tore down the axle and measured everything. Also pressed in the new wheel studs in to the allow shafts.
PostPosted: Tue Jun 27, 2017 8:40 am
I forgot to post up here, last September Victor hooked me up on some new winch line. This is the new Superline XD that is suppose to have better UV protection. I also picked up a Factor 55 Flatlink
Brenton approves
PostPosted: Wed Jun 28, 2017 2:04 pm
Vehicle: '95 YJ
David you going to do the gear setup yourself?
Sent from my Nexus 10 using Tapatalk
PostPosted: Wed Jun 28, 2017 2:11 pm
Yep I have done a few back in the day, mostly on old cars and mustangs. I have all the tools except the case spreader.
PostPosted: Tue Jul 04, 2017 1:00 pm
Officially locked in the rear, replaced the wheel bearings, brake pads and parking brake shoes while it was apart.
PostPosted: Tue Jul 04, 2017 7:05 pm
Dead blow is my case spreader. Probably same for you. Works good. Bearings probably don't like it, but I've not had any early failures in the 8 I've done so far. No training 'cept for youtube, and web searches :drnk: :rock:
PostPosted: Tue Jul 04, 2017 7:13 pm
Nope I got my hands on a proper case spreader
Sent from my SM-N900V using Tapatalk
PostPosted: Tue Jul 04, 2017 7:34 pm
I made a case spreader once. Would have helped if I'd have made it big enough to drop in the carrier with ring gear installed. My dead blow took over after that.
PostPosted: Mon Aug 28, 2017 8:34 am
Finally had some time this weekend to work on my Trailer, I received a propane tank mount for Father's day so I mounted this up. This forced me to relocate the battery to under the seat. I was able to upgrade to a higher gauge wiring and install an inverter that I have had for over a year. I also hooked up the charge wire so the trailer batteries will charge off the Jeep while driving. Need to mount the skid plates back on and I am ready for Naches.
PostPosted: Mon Aug 28, 2017 9:19 am
Needy Fucker
Vehicle: '12 Moo
:thumbsup: :thumbsup: :thumbsup:
PostPosted: Mon Aug 28, 2017 2:28 pm
Badass. I remember we were talking about that project up at Evans during Burning Wang.
PostPosted: Tue Apr 24, 2018 8:24 pm
I bought some Vision X headlights at the swap meet, and scored some brand x light bars for free so I upgraded my lighting a little bit.
PostPosted: Tue Apr 24, 2018 8:27 pm
I also upgraded my tires, I decided to give the Milestars a try. Running 315/70/17 (35") on JK wheels and spydertrax adapters.
I wanted to go with a 17" rim so that when I buy beadlocks I will be ready for a 37 in my future. The also now match my trailer.
PostPosted: Tue Apr 24, 2018 11:11 pm
Needy Fucker
Vehicle: '12 Moo
You needed new tires! :mrgreen:
Looks great! :rock:
PostPosted: Wed Apr 25, 2018 6:57 am
I know but life kept tapping into my Jeep fund, plus you got a good hike in.
PostPosted: Sun Jul 07, 2019 10:22 am
I have done a couple of random projects this spring to make things a little nicer. First was I made a storage rack for the back with some steel I had in the garage. A simple 3 piece design that bolts to the belt rail on the back. As an added plus it adds some security to the action packers in the back.
PostPosted: Sun Jul 07, 2019 10:31 am
I also finally installed a new stereo head unit. I have been gathering parts for this for a while. The end goal was to get the navigation in the dash vs suction cupped to the windshield.
I ended up using a $199 Android double din stereo. It took a little work to get a double din stereo into a 1.5 DIN space but it fits. I am running GAIA maps and Waze for off and on road navigation, I also have Torque with a $10 Bluetooth OBDII reader to check the engine. I threw in a backup camera for the hell of it.
I can run basically any app from the Google play store so I have Pandora/Youtube when the kids are in the Jeep. I also have downloaded the GoPro app so I can control it if it is on the bumper or on another rig.
PostPosted: Sun Jul 07, 2019 10:35 am
Last weekend my ARB compressor finally gave up the ghost, so it was a great time to upgrade to the ARB Twin. It took a little work to figure out a spot for it with the high line fenders, but I finally found a spot.
PostPosted: Sun Jul 07, 2019 10:38 am
And Finally I got tired of the sway bar disconnects so I got off my wallet and ordered an antirock. Pretty easy install with the exception of the nut that broke off in the frame for my bumper.
PostPosted: Thu Jul 11, 2019 8:28 am
Nice work dude. :thumbsup:
