It is currently Tue Apr 23, 2019 11:54 pm
Post new topic Reply to topic  [ 12 posts ]
 Post subject: spring questions
PostPosted: Sun Jan 14, 2018 6:26 pm
Vehicle: 93 YJ
I'm probably trying to find a solution to a problem that doesn't exist but I need to ask anyway.
My YJ is sprung over with some hybrid spring pack set up - honestly don't know how/where I got the springs over time.
Anyway, can springs wear out, I don't notice anything specific but they are so old that part of me is wondering if over time they have worn out and I don't notice. I know they make specific spring for a SOA application and they run about 170 each. I've also heard people just using stock springs and they work just fine.
If I'm not noticing anything in the ride or visually in the spring is there any reason to change them? If I do change them are the springs made for SOA that much better than just OEM springs?
Thanks!
Just want to hang with like minded people.
 Post subject: Re: spring questions
PostPosted: Sun Jan 14, 2018 7:22 pm
Yes, for sure, they will absolutely wear out. If you're not experiencing any issues, there's likely no reason to change anything. Yes, a spring (such as the Rubicon Express) that's designed for SOA setup IS better, look at the way the ends are wrapped and it will make sense. Stock springs work but definitely wear out much quicker.
J
PostPosted: Sun Jan 14, 2018 7:37 pm
Nut Knots
I have definitely noticed spring wear when I used just a stock YJ spring, seems like they would last a couple years before considerable amount of sag. Currently running a stock spring with an extra cut down main leaf, seems to last much longer, or st least until I snap a main.
95 YJ
PostPosted: Sun Jan 14, 2018 7:54 pm
Vehicle: 93 YJ
:thumbsup: Thanks all.
PostPosted: Sun Jan 14, 2018 9:55 pm
Not sure how much lift you have Scott, but the Rubicon Express SOA springs give like 2.5 inches of lift, added to the 5 inch or so of SOA height. That's like 7 inches.
PostPosted: Tue Jan 16, 2018 2:52 pm
Vehicle: 93 YJ
That is a concern because now I'm tall and springs are flat, 2 more inches would give me trouble getting in the garage and my COB would be worse.....
by the way, first time I've ever said 2 more inches is maybe not good.... lol
PostPosted: Tue Jan 30, 2018 12:27 pm
Vehicle: 93 YJ
Which leaf did you add? I found a set of stock YJ springs for 240.00 - thinking I can add a leaf from my current pack and have better springs (unless the set I found are worn out, not sure I'll be able to tell) but the more I look at mine the more I see a sag in the spring.
PostPosted: Tue Jan 30, 2018 2:37 pm
Nut Knots
I cut the eyes off a yj main leaf
95 YJ
PostPosted: Tue Jan 30, 2018 5:41 pm
Vehicle: 93 YJ
Oh, ok. Then inserted them under the "new" main leaf in the new stack?
PostPosted: Wed Jan 31, 2018 7:22 am
Nut Knots
Correct
95 YJ
PostPosted: Sat Feb 16, 2019 8:02 pm
Vehicle: 93 YJ
So... I found a set of new YJ stock springs, bought 'em and installed them. Easily 100x better - however, the front didn't last. I'm a month in and they have a negative arch already. So, I'm going to shell out the cash for the RE springs, thinking the 5 pack. My question is... before I spend the money is there another option built for SOA that's not 170 per spring?
PostPosted: Tue Feb 19, 2019 10:16 am
Stock, no lift late 70's 5 leaf wagoneer front springs work great, but they won't just bolt on, they are slightly longer. Little bit of fab required, like very little. Depending on how you install them, due to offset pin, you can keep your axle in pretty much the stock location, or flip them around and push the axle fwd or bkwd depending if front or rear application. IIRC the pin is offset 1.5" or maybe it was 2". I can't remember.
Users browsing this forum: No registered users and 2 guests
