It is currently Sat Jan 19, 2019 5:13 am
Post new topic Reply to topic  [ 8 posts ]
 Post subject: AGM bettery chargers
PostPosted: Sat Sep 30, 2017 7:11 am
Vehicle: 98-TJ
Battery in the TJ randomly went dead (3-4 volts) after sitting for 3 days.
My charger thinks it take it to 12 volts but the second you remove the charger it goes back to 3-4 volts in less than a second.
Pretty sure it's time for me to get a AGM specific charger/maintainer. Searching through some older posts looks like the Optima charger and a NOCO one is popular.
How are these chargers working for you all longer term? What one should I buy?
98 - TJ
 Post subject: Re: AGM bettery chargers
PostPosted: Sat Sep 30, 2017 8:02 am
I have multiple Deltran Battery Tenders, I have the waterproof one outside mounted to the side of the house where I park the jeep and trailer and I have the mulit bank unit on my workbench for the Powerwheels and Mustang Batteries.
I think there was a crawl article about running a lead acid battery in parallel to revive AGM batteries with a non AGM charger.
'04 LJ on 35's
'11 Jeep Extreme Trail Edition Camper on 35's
'97 ZJ TSi with lots of cutting
PostPosted: Sat Sep 30, 2017 8:19 am
If you pull it and get it to the shop we can bring it back to
Life then just get a battery tender to keep it alive.. you might have a draw too..
90 Jeep Comanche 4.0L AW4, 231 2 low Tom wood's SYE, Waggy Dana 44's 5:13 Detroit Clayton's long arms, 6" lift, 35" Maxxis Creepy's, Trail-Ready Beadlocks, Custom bumpers, 3x6 box tube rock rails,LOT'S OF BODY DAMAGE
04.5 Chev HD2500 ext.cab longbed, Dirtymax, Duramaxtuner ECM & Edge CTS moniter
Auburn Car Repair & Offroad. 253-939-5019
PostPosted: Sun Oct 01, 2017 6:49 pm
We have the Optima charger and it has worked well. You can also try a normal battery charger, hook up your AGM and a 2nd NORMAL battery w/ jumper cables and then put the charger on it.
PostPosted: Sun Oct 01, 2017 7:11 pm
I use the Noco 15000 (15A) unit and it's been very good. Restored an Optima red top that I thought was beyond saving. Hoping to do the same with an Odyssey I have here too. I looked at all the latest chargers and studied the technologies behind AGM batteries and using the correct charger. I don't think the Optima charger and most of the "smart" chargers are setup to properly charge AGM batteries. You need a fairly large amount of current (amps) to charge an AGM battery, especially when it's low on voltage.
Anyway, people have used the Optima charger with success but I've concluded on my own that the NOCO chargers are more suited as long as you're using a 15A or larger unit.
PostPosted: Sat Oct 07, 2017 10:07 am
Village Elder
Vehicle: '04 Jeep LJ, '72 Toyota FJ40 LandCRAWLer
I currently use the Optima charger for both my Optima and Odyssey batteries and they can be revived from dead very easily if the rigs have been sitting a long time. I recently added an Odyssey charger as well as a CTEK, both designed for AGM batteries and will be doing some testing with them. All of these are designed with a maintenance made where they can be left on the batteries indefinitely. I don't think you can go wrong with any of them, the CTEK being the smallest and easiest to deal with.
www.crawlmag.com
PostPosted: Sat Oct 07, 2017 10:58 am
Vehicle: 98-TJ
Did this and 24 hours later it was good to go. After it had power I could see that every illuminated switch was in the on position... Time to train Grandma, no kids playing in the Jeep.
98 - TJ
PostPosted: Sun Dec 24, 2017 8:00 am
Vehicle: 98-TJ
Ended up buying the smaller of the Optima chargers. So far I have been very happy with it.
98 - TJ
Users browsing this forum: No registered users and 7 guests
