It is currently Sat Jun 06, 2020 8:57 am
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Jeep woes..
PostPosted: Thu Apr 30, 2020 1:47 pm
Vehicle: 93 YJ
Refresher for those who don't know or remember the Jeep (it's been a while)
1993 Wrangler, automatic (AW4) with NP231 T-Case.
Jeep will drive but doesn't seem to shift and yet the RPM's hover around 2k
I can shift manually from Low to 2nd to 3rd. Reverse works fine.
Starting from a stop it takes a while to get going.
Speedo and odometer do not work.
A while ago I replaced the shift fork in the t-case.
Any ideas what might be wrong? Is there a solenoid or relay that would have gone out and won't allow it to shift? something simple? I checked where the cable goes into the t-case and the speedo gear seems fine.
Help. :)
Just want to hang with like minded people.
 Post subject: Re: Jeep woes..
PostPosted: Thu Apr 30, 2020 3:50 pm
Vehicle: 93 YJ
Replaced the TPS, no fix.
It seems to be stuck in 2nd or 3rd. I can put it into 1st, drive and manually shift into 2nd then around 2500 rpm I shift into D, RPM's drop about 300 but it doesn't seem to change gears. Then when I take off in D it's almost like the transmission isn't engaging but it is, there isn't a RPM spike.
Users browsing this forum: No registered users and 7 guests
