It is currently Fri Feb 22, 2019 9:51 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2  Next
PostPosted: Wed May 29, 2013 11:24 am
My wife had been driving a bone stock '99 grocery/kid hauler for a couple years now, and was a little jealous of my newer truck. I thought she might appreciate some mild mods, but more importantly catch up on some needed maintenance (that's how I justified the mods to her ;) ).
The front axle was developing a bearing noise, and I knew I want to go to a 31-32" tire, so I re-geared another housing with some slightly used 4.10 Spicer gears I bought from John H. I cleaned and painted everything before installing new ball joints and OEM style upper bushings.
While the housing was on the weld table, I added some plate to the front of the upper right control arm tower, and welded on some 1/4" plate skids to the lower link mounts.
New Spicer u-joints in freshly cleaned stock shafts. I did eventually paint them before install.
PostPosted: Wed May 29, 2013 11:37 am
:thumbsup:
PostPosted: Wed May 29, 2013 11:40 am
Vehicle: 1987 XJ "Skully"
Lifted , 4locked and armored.
WARN M8000
Yukon chromoly shafts
:thumbsup: That looks awesome! But where does she have to go to get groceries? The other side of wrecking ball? :eek2:
T.L.
PostPosted: Wed May 29, 2013 11:45 am
I guess we'll call the axle swap and suspension upgrade phase 1. :mrgreen:
I had been collecting suspension parts for the Jeep since we bought it. A nice pair of used Rubicon Express 3" coils were given to me by my friend Hans, along with a set of factory 16" alloys that I will install later. Victor donated a pair of RE upper adjustable control arms, some Teraflex shackles, and a track bar he no longer wanted. I spec'ed out a pair of Old Man Emu 2.75 medium duty leafs, and a set of Bilstein shocks, and bought them from Auburn Car Repair and Offroad.
The only parts I needed to get started on the lift was a pair of lower control arms. I fabbed up a set of extended arms using .250 wall tubing, OEM style bushings on the axle end, and some RE cartridge joints I've had collecting dust for 5 or 6 years.
The track bar I got from Victor had the lower bolt rusted solid in it, and I roughly cut it out of his axle a couple years ago. The bushing was all chewed up too, so I found a lower end I had kept from an old Rusty's track bar from my old XJ.
The Rusty's joint welded to the mystery track bar.
The Rusty's joint had already been drilled out for a 7/16" bolt. The bigger grade 8 bolt looks better than the pencil thin stocker.
I also upgraded the worn out, cheap rod end that the track bar originally came with, to a new kevlar lined Chromoly rod end. Here's the upper bracket I made for the rod end. It drops the mounting location down about an inch.
I don't really remember where I got this dropped pitman from, but it matched the upper track bar drop, and keeps the stock steering linkage at a decent angle.
Old axle out, prepping the rebuilt one.
PostPosted: Wed May 29, 2013 11:51 am
I'm secret-spot HOT
Vehicle: Snow camo'd 2000 XJ
woot! :woot
hopefully someday my welds will look like that :(
ΜΟΛΩΝ ΛΑΒΕ
PostPosted: Wed May 29, 2013 11:58 am
While the axle was out of the way, I replaced the rear main seal. I also noticed this piece of beautiful Jeep engineering. I guess its for pinion clearance on low rider Jeeps. It was unacceptable. :thumbsdown:
The Jeep has a nice stock tube exhaust manifold, but it necks down to this puny 2" pipe with a huge dent in it, then back to 2 1/2" pipe :dunno: I don't get it.
Great for exhaust flow :roll:
The new and improved down pipe. Mandrel bent 2 1/4" tubing to 2 1/2". The shiny mexichrome heat paint should be worth at least 2 HP.
Axle in. So fresh and so clean.
New Timkens. The axle was also treated to new rotors and pads.
PostPosted: Wed May 29, 2013 12:06 pm
Here's how it sits right now, Monster truck high. My 3" coils and 2.75" lift leaf springs have netted about a 4 1/2" lift! Not exactly what I was going for. So now I have some driveshaft vibes to deal with.
Hey John, how about a quote on SYE kit? :spend :bang:
Phase 2 plan was supposed to be installing a 4.10 ratio 8.8 rear axle, but if I have to go to a SYE, it may happen at the same time to get the pinion angle right.
PostPosted: Wed May 29, 2013 12:12 pm
Vehicle: 97 TJ Sport
Do you have a sandblaster?
PostPosted: Wed May 29, 2013 12:14 pm
I have access to one, and I'm OCD.
PostPosted: Wed May 29, 2013 12:15 pm
I guess so, everything was very clean. :thumbsup:
PostPosted: Wed May 29, 2013 12:16 pm
That thing looks good!
PostPosted: Wed May 29, 2013 12:22 pm
Needs more Duratrac. :brows:
PostPosted: Wed May 29, 2013 12:42 pm
mmmmmmaintenance?
Vehicle: .
09' JKU-R
93' Zombie CYJ
04' SuperDuty Diesel
Sweet....
So you do maintenance eh? :brows:
Quitters Rule
PostPosted: Wed May 29, 2013 12:47 pm
I love how clean you make everything. That's one thing I've struggled with. Never invested in a blaster, or even a parts washer cabinet. Of course, working out of a garage has its limitations. :(
Great work!
PostPosted: Wed May 29, 2013 1:08 pm
Vehicle: 99 TJ
08 Dmax
Great work!
X2.....great work!!!
PostPosted: Wed May 29, 2013 1:11 pm
Club Member
Vehicle: cherocar
You may be able to fix the vibe with just dropping the trans cross member 1". I made a couple out of two 1" tubes welded together and drilled for spacers. Fixed it way back in the day for me. I think I have them on my shelf?
Erik
Cherokee, 4 mud tires, right hand glove box.
PostPosted: Wed May 29, 2013 1:28 pm
Team Cupcake
Vehicle: 97 TJ & 97 XJ
Looks good, as usual Jeremy. :thumbsup:
Two time and reigning Scavenger Hunt Champions.
PostPosted: Wed May 29, 2013 2:14 pm
That's the plan. :thumbsup:
I was going to try that first.
Galford wrote:
Sweet....
As little as possible.
PostPosted: Wed May 29, 2013 2:24 pm
Back in the day I had Stan's redo my down tube b/c that drove me nuts too, the necked down/dented thing had to go. They put the bung in the wrong spot and the first time I wheeled after that my front DL wiped out my O2 sensor. I'm sure you're smarter than Stan's, but thought I'd mention it... Looks good dude! :thumbsup:
PostPosted: Wed May 29, 2013 2:57 pm
Vehicle: MJ + YJ + WK
Looks good Jeremy! Glad you were able to make use of the parts.
Or the new Toyo AT II.....
What size tire/wheel are you planning on going with?
http://www.masterpull.com --Theres a reason I'm so good at getting stuck
http://www.amsteelblue.com -- Best prices on Amsteel Blue winch ropes.
PostPosted: Wed May 29, 2013 3:25 pm
Thanks for the compliments. I just hope the springs settle a little bit.
LT265/75/16 on factory Jeep 5 spoke Icon wheels. I might look at the AT2's for my truck, but that Duratrac's look cooler for the Jeep, and that's all that really matters at the mall parking lot.
PostPosted: Wed May 29, 2013 3:58 pm
I'm sure you have done it, so I apologize, but did you do the final torque on the springs/shackles on the ground?
For tires, also take a loog at the Cooper
PostPosted: Wed May 29, 2013 4:24 pm
Yep. I'm going to throw a bunch of weight in it and drive it around a bit, see what happens. It's going to get bumpers eventually, and that will help some too.
Paul wrote:
For tires, also take a look at the Cooper
Will do. :thumbsup:
PostPosted: Wed May 29, 2013 5:27 pm
Vehicle: 97 Sport
Very nice Jeremy. So how does she like it?
Jesus was my co-pilot until we crashed in the mountains and I had to eat him.
PostPosted: Wed May 29, 2013 5:31 pm
Been running the new Toyo AT's on the GFs Tacoma all winter. They do not suck. :thumbsup:
PostPosted: Wed May 29, 2013 7:55 pm
***SOULDOZER***
Vehicle: Ginger Geep
Your wife's grocery-getter has a more bling front axle housing than my wheeler. :(
:roflmao:
Looks great!
'97 XJ Trail Rig
'04 Duramax Tow Rig
MASTER-PULL--AMSTEEL BLUE
The Leader in Synthetic Ropes.
PostPosted: Wed May 29, 2013 8:38 pm
If you're curious as to how that size is going to look, we have a spare 265/75R16 AT II mounted on 5.9 wheel. I'm sure Emilio will let you borrow it. Or just head to the shop and we can throw all four on.
PostPosted: Thu May 30, 2013 5:43 am
Cool, thanks. I may take you up on that.
I dropped the trans crossmember using some spacers last night and took it for a drive. It took care of about 80% of the vibration, and I was able to drive it at highway speeds, but its still not right. The pinion and t-case u-joint angles aren't complimenting each other at all, so I'm going to go ahead and install the 8.8 rear axle. I can then adjust the pinion angle before I weld the perches. If that doesn't solve the vibe problem, then its SYE time.
PostPosted: Thu May 30, 2013 8:58 am
Why does my nose hurt?
In before Jeremy has to buy his wife a new car since he ended up building another XJ.
98 TJ
98 Dodge CTD
00 XJ
PostPosted: Thu May 30, 2013 9:01 am
:roflmao:
Users browsing this forum: No registered users and 7 guests
