It is currently Thu Apr 25, 2019 11:40 pm
Post new topic Reply to topic  [ 573 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20  Next
PostPosted: Fri Jun 22, 2018 11:16 am
Been driving this on the street a little bit here and there. Took it to the scales and had it weighed. 4500 lbs with me in it, full fuel, but no skid plates. No tailgate (30 lbs) and only had recovery gear in it. Without myself and fuel, Jeep would weigh approximately 4250 with skids bolted back on. I'm pretty happy with that, but I may try to knock off ~250lbs later on.
Here's a breakdown of the potential savings for each item (not their weight, the SAVINGS):
Convert main skid to 6061: 50 lbs
Convert Links to 7075: 20 lbs
Replace tailgate with 6061: 25 lbs
Convert rockers to 6061: 70 lbs
Swap corner armor to 6061: 50 lbs
Convert engine skid to 6061: 16 lbs
This is all based on density, areas, known weights, and first hand knowledge from fellow Jeepers. I don't see links as a worthwhile swap considering I have chromo links. If I swap all that out, I'd save 226 lbs plus the weight of the fuel cell swap that I'd like to do, another 80 lbs if I swapped in an aluminum block LS. Keep in mind, there's no spare tire back there, so that adds ~150 lbs with a mount. If I chop off the rear frame I'd potentially save a little bit more. I think it's possible to make this TJ around 4300 lbs race-ready.
Made up some new rear shock mounts that are 0.75" lower. Should be able to redrill the lower mount and drop it another 0.5". This should get me another ~1.25" in rear uptravel which will help quite a bit in the big stuff. Going to stick with 2.0 C/Os for a while longer. Still need to notch my frame!
Picked up a SWAG finger brake and a Crossfire plasma CNC. Crossfire should be here next month. I'll let you all know how I like it.
PostPosted: Mon Jun 25, 2018 3:18 pm
Not sure where your reply went PNWJeeper but the table should be sweet. :dunno: :mrgreen:
Forgot to post these random driveway shots of the mall crawler. Been driving it on the weekends and might put it into a car show soon. Hoping to have my half doors done and on the Jeep with the 3D printed hinges in the next couple weeks. Also hoping to get out to Naches in the middle of July.
My other two projects. The 2008 BMW 135i is getting two new OEM turbos and fluids. 300hp/300ft-lbs from the factory. It's getting a 7" intercooler, a tune, intake, and downpipes next year. Raptor is getting a trans tune and 37s with mid perch. I'll grab some 2.5 4" bumps and fab mounts for it eventually. This is my main DD so not much to change on it to keep it reliable and somewhat of a sleeper for the dunes and whoops runs.
diggin this side profile
Also forgot to post this. 2 degree camber bushings :mrgreen:
PostPosted: Mon Jun 25, 2018 7:24 pm
Vehicle: 98-TJ
BMW needs this:
http://www.ad-eng.net/store/p25/AD_Engi ... i_%29.html
and
http://www.ad-eng.net/store/p44/ADE_135 ... _Kit_.html
and
I think he has a 4L80 trans kits coming out....
98 - TJ
PostPosted: Mon Jun 25, 2018 8:27 pm
ryan2l wrote:
That is pretty cool! I’ve seen the single turbo setups but that’s different. Also like his 8.8 conversion. I’m not planning to beat on mine so hopefully the rear end will last. There’s quite a few guys running 500hp with bolt ons so I’m going that route first. I doubt I’ll want more than that for quite a while! Thanks for posting these, I’ll save them for later. :cool:
PostPosted: Mon Jul 02, 2018 4:24 pm
Got out and hit Naches yesterday. Pretty fun jamming the logging roads with the new power. Jeep held steady at 60 mph with no major issues. Steering is super smooth and stable, jeep itself is also extremely stable. Still have a number of small items to clean up and fix. Main focus after this is fixing the rear clearance problems and making a new rear frame. Links hit the frame and I'm out of space with the truss to the tub so I need to come up with something different or start cutting into the tub. I'll be putting all my numbers into the 4 link calc and doing some digging on how I can make this better.
PostPosted: Sun Jul 08, 2018 2:43 pm
My current 4link numbers vs the proposed change I'm thinking of doing. Lower the upper mount at the axle 3.5" and push out ~8" from center. I think this would retain enough triangulation and also keep my geometry where I want it. I need to refresh my understanding on roll axis angle, instant center, and travel roll axis.
If anyone has input, I'm all ears. I'm no expert, just applying some of the things I've learned.
Current geometry:
https://i.imgur.com/ZDrmVsD.png
Proposed geometry:
https://i.imgur.com/HX291wa.png
PostPosted: Sun Jul 08, 2018 2:59 pm
Almost forgot - looking to chop rear frame sometime after summer. Should be adding 2.5x14 triple bypasses in the rear and 2.5 Coilovers in front to replace the 2.0s.
Here's the proposed rear frame and you can also see the proposed UCA mount for the axle. This would allow 9" of travel at the current ride height. So I can actually drop the rear another 2" while keeping 7" travel without cutting into the floor of the tub. I would need to cut holes for the shocks but I haven't designed those mounts yet. More on that later. Second crossmember behind the tub line is for the sway bar and adds more strength to the hitch. There will be plates covering the space between the tubes with reverse dimpled holes with serrations for grip. Stay tuned!
PostPosted: Mon Jul 09, 2018 12:13 pm
Someone asked about my rear shock mounts and I realized I never posted the result of my changes. This will probably shed light on the tabs welded to the square plate seen earlier in this thread. 1/4-20 hardware, sandwhiches the tub. Plenty strong.
PostPosted: Sun Aug 26, 2018 12:06 pm
Quick update: Bought a 4L80E in preparation for future power add-ons (6.0), selling the Stak D300 and AA converted 4L60E, and buying 2.5 3 tube Radflos for the rear. Also plan to put 2" Fox 2.0 bumps back there. Chopping the frame soon, just designing all of it prior so I have a final plan. Ditching the 2" hitch, not really needed. Current plan is to add a RCI 2162A fuel cell under the rear of the tub, 15 gallons should do it for trail duty. A 26 or 32 gallon cell can go in the bed if I ever race and this trail cell will drop right out. Already have a fuel pump for it.
At some point I'll be pulling the 4L60E/Stak and ordering an Atlas. Also serious considering pulling the factory wiring harness and ignition to wire in a Switch Pros module. We'll see if funds allow but I bet they do :D
Sweet servo and 2.75 turn box are also underway. Have all the parts, just need to put it in. New PSC reservoir went in, much nicer upgrade. Stuff is rolling in, hoping the new 2x2 plasma table is here within two weeks, I'm getting antsy.
Anyway, pics-
PostPosted: Fri Aug 31, 2018 7:52 am
I like the cloven hoof
Vehicle: '17 KTM 350 EXC-F
This thing is looking awesome, you need to take "slightly" out of the post title!
Larry wrote:
Most Jeep guys are cheap asses...
PostPosted: Fri Aug 31, 2018 1:49 pm
Vehicle: 97 Sport
I'm assembling a crossfire now and I'm pleasantly surprised with the quality. I have no comparison or experience with other plasma tables but it seems to be designed well.
Jesus was my co-pilot until we crashed in the mountains and I had to eat him.
PostPosted: Sat Sep 01, 2018 11:19 am
haha thanks Lezbone! I don't think I wheel enough to actually be hardcore :roflmao:
That's good to hear! I should have mine any week now. I'm chomping at the bit, I have a bunch of projects lined up for cutting and the suspense is killing me! I really need the table to cut the frame and burn out some shock mounts and tabs.
PostPosted: Mon Nov 19, 2018 4:25 pm
Whew. A lot has happened in the past couple months. I purchased a Langmuir Systems 2x2 plasma CNC table with water table add-on. I use it with my Powermax 65 from Hypertherm and it's been pretty awesome having my own table! I extended it to 25x34 to cut a few larger items for my Etsy/IG/FB business.
Onto the 4L80E swap again. I went back and forth on what I wanted to do. I was gonna leave it all stock, just add the cooler, keep it simple. Well, that didn't last as I was heaving around the 60lb torque converter and read about all the small changes to make to a 80E in order for it to run well. I bought a Jake's Performance torque converter, 10.5" and 3000 stall. Weighs about half the stock converter. To help the converter, I'm still use 8AN lines and huge cooler but also added a Transgo HD2 shift kit. This should make for a clean and easy swap with great performance that I can count on - no more blowing out 3rd gear on the lakebed :D
Since I was already going to be changing the tune and I'll want to yank the radiator to test my Volvo fan, I'm changing out the cam. I'm going with a Brian Tooley Racing Stage 3 truck cam. BTR sells these as kits and right now they're free shipping and 10% off. Should have a nice chop on the idle and pickup quite a few ponies.
Onto the rear frame and suspension....I'm not chopping the rear frame. Don't have time and just don't want to mess with it. Bummer for those watching for that. I designed a cool little enclosure that mates with the inside contour of the tub and covers the shocks. It has a rubber seal at the top to keep the shocks separate and outside the body but the upper body of the shock protrudes through the tub and mounts to the cage. I even sourced a pair of Radflo 2.5x14 triple bypasses but I just don't want to deal with it at the moment. Maybe on the next rig.
New plan is to cut off the existing bump stops and fab something for 2" 2.0 Fox hydro bumps and add Fox 2.5x12" with DSCs to the rear. If I can't live with this, then maybe I'll cut up the rear, but I bet it's plenty for me right now. Besides, with the amount of mall crawling I do, I will barely use the travel.
Pics of the frame ideas I had since they were designed and done and I might as well show them off:
Changed from holes to oval cutouts
I have another update following this...
PostPosted: Mon Nov 19, 2018 4:30 pm
Steering will be finished soon. Added a Genright twisted pitman arm and a Sweet .250 servo. Just about done, had to get creative with the servo mount. Still a 4gpm PSC pump and 2.25 bore 1.125 rod double ended PSC ram. I also took my tilt column out and made a set of fixed brackets with my cnc table.
Took my dash off for hopefully the final time. I cut out ALL the extra circuits cleanly by removing the pins and then reassembling the plugs. I will be doing the same with the underhood harness, just not sure if I 'll get time before KOH. This took a few days but well worth it. I routed the extra fuse block positions to the switches and circuits behind the dash. It makes it look factory and it's very clean now. No mess. I can't wait to ditch the unused Jeep plugs and circuits out of the main underhood harness. I might even remove the factory fuse block for a simpler one.
PostPosted: Thu Jan 10, 2019 10:07 am
edit: remove this post for more info below 3/29/19
PostPosted: Thu Jan 10, 2019 10:12 am
Went with a shorty style dipstick to keep the engine bay a little cleaner and easy to work in. Also didn't want a Lokar one, they're hard to fill up. These are on ebay.
Made a toddler bed for my nephew. Cut all the plates on the cnc plasma. Man this thing is handy to have.
When I did the BTR stage 3 cam I also installed a LS2 timing chain and Melling M295 oil pump. New springs and valve seals. New cam bolts.
Went with a 3000 stall 10.5" converter from Jake's Performance. Stock 4l80e from a van has a 60lb converter that's around 1300 stall. No thanks. This should make for a much snappier throttle and launch with better performance all around.
Still playing with the steering but so far it's powerful and just needs some friction removed to make it faster.
Machined a 300m sector shaft at work. I designed it, cnc machinists brought it to life. These are not for my car unfortunately.
PostPosted: Thu Jan 10, 2019 10:18 am
No time for bypasses this year so I'll do that after KOH. I need to clearance the frame for the lowers and make low profile upper link mounts on the axle. That's one of the last big things to do.
Few more random pics, sorry if they're upside down. Here's the crossmember for the 4l80e to D300. It's clocked flat to clear everything. Side plug for the trans controls. Extra VSS plug added. New 4l80e internal harness. Winter's shifter kit. HD2 shift kit from Transgo. Should go pretty well. Still have the bigass griffin cooler if temps rise. CM has a cutout to remove the tcase and drop the pan if needed.
Cleaned up the wiring even more and added a 120a relay, 150a breaker, and 40a fuse bank for now. Will add more if needed but this should suffice. I can add larger gauge wire in the future and run all accessories off this relay and go without the underhood box if I want to. That might be more of a nightmare than it's worth. We'll see.
All buttoned up with TBSS intake, UNI air filter (4"x11" with prefilter - the best!), PTM 92mm throttle body, BTR stage 3 cam, Melling M295, and LS2 timing chain. Should run pretty well.
Started and ran it last night. Time to button up everything, check all fluids, grease all joints, check all bolts, and get the driveshafts and rear links sorted. Almost there with plenty of time to spare. Need to swap the power steering pump on the Raptor but that should only take half a day.
PostPosted: Tue Jan 15, 2019 12:23 am
Vehicle: 1978 CJ5 Getting stretched, rear linked and LS powered
So what makes UNI air filter (4"x11" with prefilter - the best!). I'll throw my $60 AEM filter and $25 prefilter in the garbage if there's a good enough reason. Educate me please.
My CJ6 Build
PostPosted: Tue Jan 15, 2019 9:49 am
Those filters are fine for most people. Unfortunately, to get the flow numbers they require on that type of fabric filter, it must allow a certain amount of air to pass through the filter. This means not all the fine dust particles are caught, especially since it's a dry filter. The prefilter may do that job to some extent but the base filter should be the last line of defense against silt and dust. I had ZERO dust from KOH in my intake tubes. Zero. None. Clean as it was when it was brand new (installed).
Foam type filters with oil are the only filter that will ever go on an offroad vehicle that I own. I've used the K&N style paper filters and so have others that I've wheeled with - they DON'T WORK for our application. As soon as you hit dust, it's letting it pass right through the filter. Also, most people put on a filter that's WAY too small for their application. Those little 4" cone filters from Vatozone do not provide enough flow or protection especially once the dust hits.
FWIW, I run an Airaid intake on my Raptor that came with the truck. I clean it when I do oil changes and it does fine and even handled KOH fine - but it HAD to be cleaned after KOH. I ran this UNI filter for months after KOH without cleaning it and it didn't need it at all. It's THAT good!
PostPosted: Wed Jan 16, 2019 8:48 pm
That's it. I'm sold. Thank you for the information. Dust is my main concern when out on the trail. I want my LQ9 to live as long as possible. Thank you very much for the information!!!!!
On a side note, have you developed a great way to bleed all the air out of your 6.0 liter when filling the coolant system? I've been told to leave the steam vent hose unhooked from the throttle body and fill the block through the upper hose 1st till it pee's out the steam hose. Then hook that up and keep pouring into the upper hose till the rad fills to the upper hose fitting. Then hook up the upper hose and top it off. Is that correct?
My CJ6 Build
PostPosted: Thu Jan 17, 2019 9:15 am
No problem! I used to run those fabric filters and after my first KOH my intake was full of dust. I ran a Uni filter on my 4.0 after that with zero issues. Trevor has that one now, hopefully he’s using it. :roflmao:
I wish I had a 6.0 :mrgreen: but it’s the same process haha. I typically don’t bleed the air system because the pump should be pushing fluid. So essentially it should bleed itself. I’ve never had an issue with my current Griffin radiator besides the pin holes that were my fault from mounting a trans cooler through the fins like a dummy.
I run an overflow bottle off the nipple below the cap of the radiator. The line runs to the bottom of the bottle so if it has a vacuum it will suck fluid back into the radiator or push it in from the bottom. The top is vented with a coiled line for overflow from the bottle itself. Initially it was pushing coolant out the whole time and Kevin helped me route the steam line properly. We basically drilled and tapped a hole in the front of the radiator to run the steam return. I had it running through my throttle body initially but that’s an optional step for very cold climates to keep the throttle body and intake warm. Not needed here IMO. I just ran the steam port straight to the tapped hole in the radiator this time.
I also run the GM orange coolant and it works well. No issues thus far with heat, even when it was a few quarts low. Volvo fan cools everything really well even though my shroud is not the best. I now have the LS computer controlling fan activation but still have a single pole double throw switch to manually operate fans if needed.
PostPosted: Thu Jan 17, 2019 10:51 pm
Thank you again. My coolant system is set up same as yours. I was having problems with the tstat not opening and I thought it might have been trapped air. I’m gonna boil the old tstat and see if it opens correctly. Might b stuck. Well thanks for d info. Looking forward to more of your updates.
My CJ6 Build
PostPosted: Fri Jan 18, 2019 9:27 am
Both t-stats, old and new one, opened same time in the pot last night. On 1st start I had flow to the heater core shut of completely. I've since learned that's a big no no unless you swap out the LS tstat for an SBC tstat. Can't block that flow or the water pump cavitates and the tstat no open. Now that I know that I'm good to go.
My CJ6 Build
PostPosted: Fri Jan 18, 2019 10:19 am
No problem!
I have no tstat in mine :mrgreen: I plan to run one eventually but I haven't had issues. A lot of the guys doing these swaps leave the tstat out. Just preference I guess. My WP nipple was swapped with an SBC straight to go right to the radiator. Works well.
PostPosted: Fri Mar 29, 2019 7:37 am
Forgot to update this. I'll try to post the updates as best as I can.
Got the front end buttoned up and ready to have the lower crossmember rewelded. I had a stress crack in the weld around the pass through tube for the steering box shaft. I missed the entire bottom of the tube that connected it so I’m not surprised it cracked. I’ll glue it together this week and paint the exposed tubes. I removed the temporary crossmember and ground smooth all the connections. The 3” flap disks made this quick, not sure how I ever lived without these smaller discs that mount to a die grinder.
I had an issue with the spacing of my Goat Built alternator and TC pump brackets. The tc pump spacing was 1 rib proud of the main pulley so I think I have it fixed. It was pitching belts at higher rpm and I lost a belt at about 60mph on a lakebed last year.
TBSS intake is mounted but is super close to the hood. The TB is actually touching the fiberglass when fully closed. Luckily a nice endmill will fix this with a chamfer :D
4L80E fits into the TJ trans tunnel after the tab on the drivers side is cut off. Had to replace the internal wiring harness after I accidentally rolled the trans onto the original. They’re about $42 on Amazon if anyone needs one.
Drew up a bracket to mount the Lokar throttle cable for LS1. I’ll snap some pics when it’s done. I 3D printed a test piece that fit really well until I broke it.
Baby steps but almost there. Taking a few days off at Christmas to get all the little things done and get it out for a test drive. Still not sure if I’ll have time to mount my shiny used 2.5x14 bypasses. Fingers crossed!
Last pic is TB good clearance but it’s upside down
Finished
Trans is in for hopefully the final time. For anyone that buys a converter from Jakes, there is an allowable gap of .120” to .187” between the flex plate and converter face prior to installing the bolts. Keep this in mind so you don’t panic when everything is bolted together. This came straight from Mike at Jake’s Performance.
Had to beat the trans tunnel a bit but I think everything will fit. Hoping to have the D300 in place tonight. Advance Adapters makes a shorter input retainer for the Dana 300 with a 6209 RS C3 sealed bearing. The only problem with this is the bearing doesn’t actually seal with their design. I’m not convinced it’s a truly sealed bearing either. So I designed a mod to put a typical seal on the front of the input retainer. It uses SKF 21352 which is a popular trailer axle seal. We had to turn down the input shaft major diameter .005” to make a decent seal surface. The seal is a slight press fit into the newly machined retainer but I’ll use sealant on all the surfaces of this retainer. I can’t have gear oil in and the trans again.
My old crossmember for the AW4 fits pretty well for the 4l80e so I’ll be chopping it up to use with a new mount. Time to cut more metal.
3D printed finger brake dies. Only broke one and it was due to misalignment on the brake and being a fool with the pressures.
Shock clamps printed for Paul and Kevin at FullStack Motorsports
PostPosted: Fri Mar 29, 2019 7:46 am
Dash is wired. All of it. Fans are controlled by PCM now with a SPDT rocker switch for override. Need to design and 3D printed two adapters for the dash to mount my switch panel and iPad. Slowly put things together that were lingering like misc nuts and bolts, the cowl, and mounting the pcm and fuse block.
Went with Tom Woods for the shafts. Ordered on a Tuesday and had them here today, Friday. They were very helpful and made them exactly to order. No issues at all. Highly recommend them. I haven’t used them in 10 years and they’re still great to work with. I went with 1310 CVs and 1350 slip yoke at the axle end, all Spicer non servicables. I’m very happy with them and the whole experience.
Had a small interference issue with the bellhousing. I don’t know how this didn’t come up before. Perhaps the suspension settled slightly and I didn’t notice. Either way, I had to chop a little off the bellhousing where the bottom cover bolts up. Lost one of the bottom cover bolt holes. Oh well. Small sacrifice for a one piece shaft. Picture makes it look much worse than it actually is. All good now. Front has 5” uptravel in these pics since I lowered everything down. I will run it at 5” and see if I can bottom it out as hard as the rear.
Reusing the previous front shock crossmember but this time putting in some stubby tube connectors that interlock. Huge time saver and this will protect the front end if I run out of talent.
I’m designing the new rear axle upper link mounts and cutting them on the CNC plasma. Should be fairly easy but I’ve said that before!
I messed up 4 times before putting the entire rear link bridge in CAD. I didn't make this bridge, just hacked the top off a few years ago. Each face is not square to the other. I was also angling the mounts 10 degrees by pointing them to the UCA mount on the frame. Add to that the 45 degree and 59 degree angled sides on the link bridge and you have a very complicated setup. After the 4th fawk up I put down everything and spent 2 hours just reverse engineering this damn bridge. Designed it all in Solidworks, got it setup for the cnc plasma, and double checked everything twice. Cut it out and VOILA! Fit perfectly. It looks easy to do but NONE of these corners are 90° and the links may have to be shortened an inch If so, I may just say fawk it and order some 7075 because these have already been sleeved once. WOD has these links for $135 each and that's enticing
Still have to notch the lower part of the frame for the links, fab the new front shock crossmember, and straighten the front axle tube slightly. If I get time I'll also move the 2.0 Fox bumps to the rear. Still need to swap the steering pump on the Raptor and do maintenance on the trailer. It's not as tight as the last two years but still have some work to do.
before:
after:
TBSS intake swap wrapped up and done done done
Moved the 2.0x3" Fox bumps to the rear with some bump pads (second pic). Frame will get hacked off after KOH so not worried about them. They look decent. Crossmember for front shocks is in, I'll have to add those clamps later like I always keep saying. Everything under the hood looks much better than before but I want to do a big clean up after KOH to get rid of extra 4.0 harness pigtails and a few other tidbits to clean up things. (third pic)
Put in a temporary seal for the front long side of the Eaton 60. It uses two D60 seals but they wore grooves in the shaft. Still confused by this. I'll have to tear down the front end later and see WTF happened.
Stole my girlfriend's half doors and we wrapped them in matching 3M vinyl. Much easier with two people.
Bunch of link kits laser cut and CNC bent. I may have to throw one of these on my TJ this winter.
PostPosted: Fri Mar 29, 2019 7:49 am
Drove it around the block yesterday. Jeeeeeezzzzussss it's scary fast. I punched it in a large open area and the 80e downshifted, the rear end planted and squatted a bit, and the front end rose slightly. The Jeep took off so quickly I was a little shocked :laughing: Steering is very tight but always the same speed. I am growing to like it. It takes some effort to get going but no twitching at all and very powerful. Much happier with the new steering setup and the Genright pitman arm. Made some spacers for the short tie rod on the ram too, which had a small amount of binding.
Fan controls are working well, trans temps only got to around 175. I need to check the level and fill it up slightly I think. Replaced the brake line. Massaged the bump cans, thanks to Paul for the recommendation. D300 still leaks because it's a D300. Need to swap rear springs to heavier rate to get more lift in the rear for 7" uptravel at KOH.
I have to install my tunnel covers but that's it. Ready to roll.
Walkaround video:
https://www.youtube.com/watch?v=PqjSpNIWcX8
PostPosted: Fri Mar 29, 2019 7:53 am
KOH WEEK! Whew. What a week and a half. I'm going to post this in multiple parts to break up all the pictures. So much happened at this KOH and I'm so glad to be home even though we had a great fawking time! Best KOH I've had since the first one but especially because the rig did so well. We had a flash flood with massive rain showers, 50mph winds, then Snowpocalypse on the way home driving through a white-out blizzard.
The Jeep did really well and only had a few small problems. We didn't wheel as many trails as we would have liked, but we tuned quite a bit and hung out with some awesome people. The new power of the cam/intake/tune/trans made me realize just how badly I need to put in the bypasses. I couldn't do more than 40 in the rough and 65 in the smooth due to rear suspension bottoming out. I have maxed out the compression in the rear Fox 2.0s. It does feel reall good to have a transmission that HOOKS UP and GOES! It is addicting to feel the power send to the ground instantly and smoothly. I want to change my shift points and get the Jeep to a dyno. This combo is 100% what I've wanted out of the LS swap and I'm very happy with it. BTR Stage 3 cam, TBSS intake, and 4l80e with shift kit and performance converter.
I didn't like the feel of the steering wheel while we were there. I had to wear gloves or I'd get my hands and fingers caught in the wheel. The Joe's wheel is cool and large, which is great for looks and grip when I'm wearing gloves and doing technical crawling - but not good for high speed bare hands wheeling. I was walking around Hammertown and saw the MPI wheels at SDHQ. I said fawk it and bought the suede GT13 and adapter plate. Much better feel and I can yank the steering now. I need to reduce the number of turns in the box and remove the excessive resistance/drag in the column to get to 2 turns lock-to-lock. I'll post more on this later when I do the mods.
Broke in my new bumper. Mall crawlin so haaaaaaaaaaaaard.
new GT13 wheel
PostPosted: Fri Mar 29, 2019 7:56 am
Here's a few videos of sledgehammer...remember I'm a desert loving mall crawler not a real rockcrawler :f2: Don't judge my shitty crawling skills :lol:
https://youtu.be/YWCkPVlfPFU
https://youtu.be/609nxHZ5BP8
https://youtu.be/uWzRTtIkr5g
I burnt up the trans lines on the exhaust the day before we left. Rookie mistake, they detached from the zip ties. The 3D printed mounts I made did their job for the rest of the lines and they didn't fall into the driveline but I should have used a third mount from the get-go. I'll be replacing them and adding heat shield.
Tunnel cover needs to be sealed. The one I made isn't terrible but all the angles are too much. I'm going to weld new flanges on the tunnel cover with nut-inserts to make a flat tunnel cover.
Dash will get revamped with Holley EFI digital dash. It will remain a stock TJ dash for the foreseeable future. I like it and it works. Seats will get replaced before next KOH with a bucket of some sort. Center console to be redone at the same time. Hoping to make this next winters project along with cleanup, audio and radio management, and storage additions.
Broke in the Tom Woods driveshafts on Sledge. Glad I bought these, they're wonderfully made and held up to a few hits. I smacked the hydro ram mount REALLY hard a few times and it held up great. Rear end took some hits and scrapes but overall the Jeep armor did it's job well.
3M vinyl wrap held up to being scrapped on a huge rock. It kinda acts like paint when it's scratched.
Hub locks worked all week! No backed out bolts or issues, even when using suboptimal bolts.
My LS1 balancer wobbles a little bit, probably .030 to .040. I'm going to reseat it and buy the ARP crank bolt this time. If it's still off, I'll have to replace it. Main belt whines, it's shorter and not the typical routing per Goat Built instructions, 83 vs 91. I'll buy a new longer belt and try that. Still off 1 rib though even after spacing the PS pump out.
Overall, the Jeep rips and I'm excited to wheel it. Still looking for some 2" travel 2.0 bump stops from Fox or Radflo and 2.5x12 COs also from Fox or Radflo. I'm gonna get the small details worked out of the next couple months and chop this frame!
This didn't work for long so wouldn't recommend in the future unless you've got 3 hose clamps for each end. Just leaked air.
Ride home was....white....and eventful.
PostPosted: Fri Mar 29, 2019 7:59 am
For anyone else wanting a quick rundown of the LS powerplant combo now:
Engine (2002 LM7):
TBSS intake, PTM 92mm DBC TB, 33lb injectors, TBSS rail
Goat Built LS TC pump and alternator brackets
PSC 1200x TC ps pump, 5.5" pulley
Truck 5.3 Alternator
F body water pump and balancer
Knock sensor delete (might reinstall knock sensors)
truck pan, for now, swap to steel sheet pan later
BTR Stage 3 low lift cam, springs, valve seats
LS2 timing chain
Lokar LS1 throttle cable and bracket
6AN lines, no plastic clips, all braided hose, no push-lock fittings
4L80E 2wd from 94 Chevy Van
Art Carr winters shifter
Jake's Performance 3000 rpm stall 10.5" converter
GM $65 adapter
Tailshaft cut to length, 32 spline input on D300
Big griffin cooler with it's own fan
Stubby dipstick
8AN braided lines everywhere, no plastic or push-lock fittings
Exhaust
Speed Engineering block hugger headers
(these are nicer than you'd imagine and work perfectly)
Vibrant 2.5 to 3 merge collector
Black Widow Race Venom 250 muffler to dump
Harness and Electrical
PSI standalone harness, DBC Vortec and 4L60E
150tunes tune
iPad tablet and Wifi puck
Coming soon - Holley EFI digital dash
4L60E to 4L80E harness adapter
Fuel
TJ pump, regulator removed
Corvette regulator, for returnless rails
JEGS AN6 fittings, no plastic clips
Braided AN6 lines
Using existing 5/16 TJ hard line
Custom adapter from pump in-tank to top of TJ pump housing
Still plugging away at the new frame in Solidworks. I need to design the fuel cell skid but might buy the Artec version to save time. 7 weeks to EJS. Hoping to get on the trip but we'll see if I can get away.
Keeping the Poison Spyder bumper, I dig it a lot. Keeps a "stock"ish look and I like that. Using interlocking tube clamps and the bumper mount studs to secure it to the Jeep. Should be plenty stout. Lots of tube work for strength since I am losing a bit with the notch I need for lower links. Probably heavier than it should be but I want this to be strong enough to take a hit. Planning to mount B pillar to all this as well. Need to tie in the body mounts under the cargo area and a few other odds and ends to complete it. Hoping to cut from in a week or so.
And some pics of the newest project....Porsche 996 with M96 and Tiptronic. Has a knock, so engine and trans are coming out for a LS1 and 6 speed manual with limited slip. Should be a pretty good weekend car and daily driver.
Last few pics of KOH including the frozen front of the Jeep on the way home
Users browsing this forum: No registered users and 4 guests
