It is currently Sun Jul 05, 2020 4:40 am
Post new topic Reply to topic  [ 17 posts ]
PostPosted: Sun Nov 04, 2018 12:06 pm
I am shopping for long bed trucks.
This will be a truck that is used on the weekend for house projects, then will also be able to haul my SxS (1,100 pounds) in the bed and tow my travel trailer (about 3k pounds).
I don't "need" a diesel or want to maintain one, unless I trip over one cheap. I think a bigger gas motor would be fine for me.
I worked for Ford for a long time so I know the good and bad of those.
Most wondering about Chevy/GMC trucks. Maybe a 2500HD gas or something?? Anything to stay away from? Is the 6.0 enough for occasional towing or is the 8.1 needed?
Any advice would be appreciated.. :cheers:
PostPosted: Sun Nov 04, 2018 5:16 pm
Nut Knots
By the sounds of it, you're pretty solid into only needing a half ton truck. What's you budget though, that seems like that would be your biggest limiting factor right now. Is fuel mileage a concern?
95 YJ
PostPosted: Mon Nov 05, 2018 8:22 am
I would absolutely go 2500HD with the 6.0 for your usage.
PostPosted: Mon Nov 05, 2018 2:53 pm
Biggest issue with 1/2 ton (like the one I just sold last week) is getting a 8ft bed and 4 doors.
Thinking I can get a decent truck for $10k or less. Would spend more for the right truck if needed.
I don’t think fuel economy is an issue since it won’t be driven all the time.
Sent from my iPhone using Tapatalk
PostPosted: Mon Nov 05, 2018 2:55 pm
How do they drive compared to a Ford 250/350? Better because of the IFS?
It’s currently between a v10 ford and a Chevy depending on what deal I find first. Would lean to a Chevy if there was a good reason.
PostPosted: Mon Nov 05, 2018 3:36 pm
Ask Wang. He owned the exact truck I'm recommending. For your purposes I think it would do great.
PostPosted: Mon Nov 05, 2018 3:56 pm
Nut Knots
I missed the part about the 1100 lbs in the bed. Carry on.
95 YJ
PostPosted: Mon Nov 05, 2018 5:40 pm
6.0 LS > V10
90 Jeep Comanche 4.0L AW4, 231 2 low Tom wood's SYE, Waggy Dana 44's 5:13 Detroit Clayton's long arms, 6" lift, 35" Maxxis Creepy's, Trail-Ready Beadlocks, Custom bumpers, 3x6 box tube rock rails,LOT'S OF BODY DAMAGE
04.5 Chev HD2500 ext.cab longbed, Dirtymax, Duramaxtuner ECM & Edge CTS moniter
Auburn Car Repair & Offroad. 253-939-5019
PostPosted: Wed Nov 07, 2018 11:45 pm
If you can afford the diesel then get one. It will be more fun driving and towing with a diesel. Gas engine will cost you more in the end.
PostPosted: Thu Nov 08, 2018 9:12 am
I beg to differ on that one. A $100 dollar repair on a gas truck engine is $1000 on a diesel truck engine. For what OP needs to do, the GM 2500HD gas 6.0 liter power-train is more than adequate. Ownership of that LS power-train is nothing but pure joy. So easy to work on. There is nothing easy, or joyful about working on the equivalent diesel power-train. If a person needs a diesel, then by all means sure. If not, then hell no, stay away. OP don't need.
PostPosted: Thu Nov 08, 2018 10:51 am
This is VERY rarely the case, for MOST diesel truck owners.
PostPosted: Fri Nov 09, 2018 5:21 pm
No... no it won't, actually a gas drive probably cost a 1/4 of what it cost to keep diesel on the road.. and for the op stay away from dodge and ram.. unless your gonna trade in before it hits 80k
PostPosted: Sat Nov 24, 2018 4:52 pm
End up with a V10 brodozer. Finding a crew cab longbed in my price range was harder than I thought. Having worked at Ford for 14 years I am more comfortable working on this in a emergency than a Chevy anyways.
Now for some ramps to put my SxS in the back and I will be good to go!!!
PostPosted: Sun Nov 25, 2018 8:39 am
Sweet. I figured you'd end up w/ a Ford since you know 'em. :)
PostPosted: Fri May 24, 2019 10:53 am
Vehicle: '69 Bronco
I would't say that's too brodozer. You'd probably know more than I do but, I've never heard a bad thing about that Ford V10, other than fuel consumption. If I recall correctly, I've even heard people compare them favorably with a diesel when towing.
Baller
Nemo me impune lacessit.
PostPosted: Tue May 28, 2019 3:52 pm
Baller
I finally towed semi heavy with it this weekend for the first time. It is definitely no diesel! It was also the first time I have not had a 6 speed trans towing in almost 10 years that was the biggest difference. Once I learned what gear and where/when to hit before a hill it is totally tolerable.
For the price (half of the diesel trucks) it totally works fine, but certainly hard after having a diesel so long. Pretty sure the stock gears and 37's don't help.
PostPosted: Tue May 28, 2019 7:12 pm
ryan2l wrote:
Baller
I'd drop that thing back down to stock.. It would help the SCREAMIMG V10....
Users browsing this forum: No registered users and 1 guest
