It is currently Sun Mar 24, 2019 5:34 pm
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Nov 08, 2018 6:28 pm
Nice work! Your trailer looks better than those aftermarket ones. As trailer tires, how's the performance of MTRs? I'm thinking of getting the nitto tires for my trailer though can't decide yet on what size.
PostPosted: Sat Nov 10, 2018 10:00 am
Vehicle: 97 Wrangler, 5.7 Hemi, Rock Jock, 4.88, Arb's
The choice in size was dictated by the size of the tires I have on my jeep, I wanted them to match.
With one trip to the rhino lining shop on them it is too early to tell how they will work out, but with the 1 trip 15 miles on the freeway they tracked well no issue.
Even though the Batwing comes with 2 brackets they will not work on the rack with the way I am setting it up. I pulled out the plasma cutter and made 3 brackets. Rhino rack sent me another set of T bolts for my 3rd bracket.
I made my own brake to set up inside of my Harbor Freight cheap'o press and it worked well for the first set of bends. I need to weld these on, paint the rack, complete the wiring for the rack then drop it back into the M416....
I hope to have some time this weekend to knock some of this out...
MY ALMOST COMPLETED 5.7 HEMI TJ BUILD
http://www.pirate4x4.com/forum/jeep-har ... 2-5-l.html
PostPosted: Sun Nov 11, 2018 6:06 pm
Welded on the brackets for the Batwing today. Also picked up a pigtail wiring set up for the rack...
Next is wiring up pigtail and paint the rack.
PostPosted: Sun Dec 09, 2018 5:04 pm
The rack is now painted, 3 coats of base 2 coats of clear.
I finished wiring the lights and connected them to the pigtail that will connect to the tongue box.
I purchased some pulley wheels with bearings and made some brackets for them. I will use these to assist in brining the rack down after it is extended.
I also picked up the hand winch to be able to use with the pulleys to retract the rack.
Now I need to figure out if I am going to bolt or weld the pulleys to the rack. I also need to figure out where and how I am going to mount the hand winch.
PostPosted: Sat Dec 15, 2018 7:35 pm
Dropped the rack into place today and mounted levels on 3 sides under the rack.
Used these levels: https://www.amazon.com/Spirit-Accurate- ... B00X2BRZYS
Next step is picking up gas struts to raise the rack and installing them...
PostPosted: Thu Dec 20, 2018 6:30 pm
I figured out the weight of the rack, bat wing, and tent. I also took into account the drag affect of the friction of the rack sliding in and out.
I ordered part # 018318W from:
https://www.liftsupportsdepot.com/lift- ... t-support/
They have 120# lift each with a 19 ¾ stroke which were the two most important characteristics I needed.
The stroke will get the bottom of the rack to 81 inches so that I have room to walk under it with a couple of inches to spare. I also purchased the extension for the annex under the tent to make up for the height.
I wanted 115# of lift but the only options were the 120# and a 100# in the stroke that I needed.
Keeping fingers crossed but I may have to play the UPS shipping game a few times to get it dialed in.
Struts should be here by next Friday...
PostPosted: Fri Dec 28, 2018 6:42 pm
To get the trailer licensed I needed to get it weighed so I ran down to the nearest scale and had it weighed.
Empty, meaning no tent, awning, etc it came up to 1,460. I booked an appointment to get the trailer inspected for licensing mid January, I was surprised how far booked out they are.
In the meantime I started on the tongue box with wiring, switches, solar and battery setup...
PostPosted: Tue Jan 15, 2019 4:37 pm
Since my last update I was able to get an appointment at the state patrol office for an inspection and it passed.
They stamped the Vin # into the frame and then used pop rivets to attach a vin tag right below where they stamped the Vin into the frame.
I took their paperwork back to the licensing office and now have a plate, tags and another 'so to speak' vehicle to buy tags for each year...
As for headway I made mounts for the struts out of C Channel cold rolled and welded them to each base tube on all 4 corners. Then I bolted the ball stud mounts to each of the mounts I welded on.
I also was able to weld/mount each pop pin on all four corners which lock the rack in either the down or up position.
A new coat of fresh black on the rack with a couple coats of clear and the rack is done...
Next step is putting the rack in the down position and then putting the struts back on, the only trick is compressing each of the struts. I think I can use a ratchet strap for that.
Once all 4 struts are on then I will mount the Batwing and Tent. I will then know if I chose the right poundage for the struts. If that works out then from that point I will work on the tongue box, electrical, ie lights, solar panel, inverter, switch panel, etc...
I thought I would have had this done by Xmas, bummer..... Still keeping fingers crossed that I can get the maiden voyage in before the snow melts....
PostPosted: Tue Jan 15, 2019 4:38 pm
PostPosted: Wed Jan 16, 2019 3:42 pm
Vehicle: '95 YJ
Cool trailer!
Quick thought, do you anticipate any issues with the rack binding in it's channels as you work your way around unlocking each corner, due to uneven force?
Sent from my SM-T377V using Tapatalk
PostPosted: Wed Jan 16, 2019 8:00 pm
Todd1803 wrote:
Cool trailer!
Thank you...
Not anticipating it because I have seen this same method used on a few other m416 builds. I also have added a generous about of lithium grease to each post.
What I am concerned about is that my struts may have too much force and I might have to exchange them for the 100# struts.
I am hoping to get a chance to put them on, install the tent and batwing this weekend.
Once that is done we'll see what happens, should be interesting...
Thanks again....
PostPosted: Sun Jan 20, 2019 7:28 pm
Started out the weekend using a floor jack and ratchet strap to install each of the 120# gas struts, not fun but done, all 4 installed.
This got me over the hump so I mounted the Batwing and rooftop tent.
I ran out of daylight so I did not get the chance to set up the Batwing or tent.
Next up is to release the struts (outside) to ensure there is enough upward force as well ensure I can still bring it back down.
Then install the tongue box and wire up the battery, lights, inverter, outlets, and switch panel.
Sooo close......
Last edited by PacificNWestJeeper on Sun Jan 20, 2019 7:37 pm, edited 2 times in total.
PostPosted: Sun Jan 20, 2019 7:30 pm
a few more pics
PostPosted: Sat Jan 26, 2019 6:57 pm
I Had the chance to cycle the struts today and I lucked out, the tent went up with a couple of light pushes. When it was time to put the tent down I was able to use 1 ratchet strap and rocked it back down into locked/travel position.
I like the Cascadia Design Denali Summit Series tent, lots of room plus sky lights. It also came with a rain fly. The vestibule is really nice and will provide a great place for the dogs to sleep. The batwing awning is perfect, it covers a lot of area. I purchased two walls for the Batwing that zip in and stake down, thinking that if it gets windy or rains the walls will be nice. I may end up purchasing more walls at some point but I want to get a trip in first to shake everything down and go from there. I still need to mount the tongue box and wire up all the lights, solar panel and inverter... Feeling like I am getting a lot closer to being ready for a trip.
Last edited by PacificNWestJeeper on Sat Jan 26, 2019 7:10 pm, edited 1 time in total.
PostPosted: Sat Jan 26, 2019 6:59 pm
Few more.
PostPosted: Tue Jan 29, 2019 4:23 pm
Went to work on the tongue box and lights and have run into a slight snag.
I need to run 5 wires through the side of the tongue box and two wires through the side of the trailer wall to the tongue box.
I was going to drill a hole and use rubber grommets like on the firewall of cars but the ones I have are not water tight.
I started looking at the 5-7 pin aviation/marine female & male connectors but haven't seen anything that has struck me as clean looking and watertight.
Any ideas on male/female watertight connector ideas would be great. Or any water tight ways to get wires through the sides of the trailer tub and tongue box.
I was thinking of something like in the pic..
PostPosted: Tue Jan 29, 2019 7:17 pm
Nut Knots
Will the connection be permanent or need to be able to readily disconnected? If you can hard wire, I would us some 5 wire SO cable and plastic compression connectors.
95 YJ
PostPosted: Wed Jan 30, 2019 11:58 am
Thought about that but then I found these guys up in Tukwila: https://jkconnectors.com
I am corresponding via email with a sales rep and might end up with some of these aircraft connectors (male & female)...
still looking for more ideas though.
thank you
PostPosted: Wed Jan 30, 2019 3:20 pm
Vehicle: '95 YJ
https://www.ebay.com/itm/WF28-7Pin-Wate ... ect=mobile
Leaving yourself room to add circuits down the road couldn't hurt.
PostPosted: Wed Jan 30, 2019 6:04 pm
I saw that on Ebay too, thought it looked good. With the few days off I had this week I got antsy and started calling and emailing all kinds of places.
Finally I found these: https://platt.com/platt-electric-supply ... ?zpid=2492
I went down to Pratt and picked them up.
This will make it simple, they are super tight so no leaking, they won't let the wire slip through and they are aluminum, so no rust issues. I'll install them and then give them a coat of black rattle can....
PostPosted: Fri Feb 15, 2019 2:13 pm
I was able to get the tongue box mounted, switch panel made and put in place, and wires ran into the tongue box.
I then fired up the lights, they all work, Yes!
I also had the chance to mess around with the solar panel, seems to charge very well. I hung it in front of the lid to test it out, but it can easily be put anywhere.
I will keep it stored inside the tongue box...
Next steps are to purchase a large propane tank and then make a mount for it.
I am on the fence as to whether or not mount water and gas cans or rotopaks or not all... Still thinking about that one..
Last edited by PacificNWestJeeper on Fri Feb 15, 2019 2:15 pm, edited 1 time in total.
Foldable solar panel. Thanks again overlandsolar.com
Users browsing this forum: No registered users and 3 guests
