It is currently Thu Feb 21, 2019 1:37 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Snow Run
PostPosted: Thu Dec 24, 2015 3:09 pm
Vehicle: 59 Willys Thing
Wanting to play in the snow Saturday Dec 26 thinking about going up road to Evans creek and past if able and if time allows turn around and go back to surprise lake area. Meet at y at 9 am. Any interest, locked and low air hopefully needed. Thanks.
 Post subject: Re: Snow Run
PostPosted: Thu Dec 24, 2015 4:34 pm
I'm Fun Sized!
Vehicle: 00 TJ
92 Cherokee
84 Yota
I'm in!!! See you Saturday
Lone Wolf Image
... "And knowing is half the battle" G.I.JOE
PostPosted: Thu Dec 24, 2015 6:02 pm
I'd really like to be able to ride with you folks. Couple questions:
I think the Jeep I got is capable of this but do you recommend I not go? I wheeled back in the day with a TJ but it has been a while. I've been itching to take this rig out on the trails but don't want to go on my own.
PostPosted: Thu Dec 24, 2015 6:08 pm
I'm Fun Sized!
Vehicle: 00 TJ
92 Cherokee
84 Yota
Watcha got???
Lone Wolf Image
PostPosted: Thu Dec 24, 2015 6:15 pm
Model:
1989 Jeep Cherokee “Laredo”, 6 Cylinder, 4.0 Liter engine
4sp Automatic Transmission, AW4, and Part time, NP 231J
Engine:
6 Cylinder, 4.0 Liter,
Custom LCA bushing engine mounts
Custom Intake with Extra Large K&N cone filter
Accel cap, rotor, 8mm silicone wires and Champion sparkplugs
Larger capacity oil filter (Mobile 1)
HO stock tubular exhaust manifold (gasket matched) with custom down pipe, high flow cat, and Flowmaster muffler, all 2.25 diameter pipe
Closed to Open cooling conversion with 2 row Aluminum
185 amp +small pulley high output alternator in stock housing
Largest fitting battery
Custom “1/0” ground cables and power cables to engine block, chassis, Starter and Battery
Custom “4/0” alternator cable
Upgraded fuel injectors
Transmission:
4sp Automatic Transmission, AW4, with 21 spline output, new CPS and cleaned NSS
Transfer Case:
Custom HD 231CJ Tera low
6 gear planetaries, Wide chain, and gears out of a NP231C
JB conversions Heavy Duty Short Shaft Slip Yoke Eliminator
Drive shafts
Stock front drive shafts in both front and rear
Front Axle:
D30 factory disconnect housing with cast UCA mounts.
4.88 Randy’s Ring and Pinion Gears and Spartan Locker
Chromo shafts
“Solid” Nodular Iron Front diff cover, JKS LCA skids
Yoke with “U” bolts instead of straps
Off Road Only U-Turn Steering Kit
Rear Axle:
D44 from 1987 Jeep Cherokee
4.88 Randy’s Ring and Pinion Gears Detroit Locker
Chromo Shafts
Raised shock mounts
“Solid” Nodular Iron diff cover
Wheels/Tires:
15 x 8” Black Steel Wheels
33 x 12.5 R15 Swamper Mud Terrains
Front Suspension
BDS 4.5” lift coils (240lbs/in spring rate) w/ 2" spacer
Custom adjustable super flex upper and lower Control Arm’s
Top eye conversion and Bar Pin Eliminator on front shocks
Disco front sway bar
HD Reinforced trackbar mount and adjustable trackbar
Rear Suspension:
Modified Rock Krawler/RE 4.5” spring pack
2" Lift shackle and adjustable shackle mounts
Rusty’s shocks with flush lower shock mounts
Removed rear sway bar
Protection:
Stock front skid with added lower lip reinforcement
Stock gas tank skid
DPG Belly Pan
Rusty’s Engine/Trans Skid Plate
2nd stock cross member behind Belly Pan
Custom 1/8” steel lower “Belt Line” panels
Front Bumper:
3”x6”x3/16” rectangular tube
Steering box reinforcement and Lower skid plate
2” receiver and two 10K “D” rings
5 gal of compressed air at 120psi with quick connect for air hose
Custom 1.5” DOM stinger and light guards
Rear Bumper:
Wrapped under lower quarter panels
7 gal of compressed air at 120psi with quick connect for air hose
Rock Sliders:
Custom 2”x3/16” rock sliders with 1.5” HREW tube extensions
4 “arms” to attach to the frame and 15 bolts per side to attach to the pinch seam
1.5” HREW tube front flares and 1.5” HREW tube rear flares to come eventually
Cage:
NWHBC designed and built “Custom” Cage
Top Exterior halo with gutter sliders and flat top rack
Exterior “A” pillars under front fenders
Interior “B, C, and D” pillars with shoulder bars and lower “V” supports at “B” pillar
Accessories:
Ramsey 8,000lb worm drive Industrial winch mounted on custom portable mount with 25ft cables able to be mounted on front or rear bumpers
On Board Air with stock AC pump, 12gal of compressed air at 120psi and 25ft of air hose
Hella “E” code crystal headlights with 55w-100w bubs, on custom wire loom
4 Hella 6” driving lights on custom folding light mount on roof rack
3 Rock Lights, 1 under each front fender, 1 above rear axle
Large Diaphragm Brake Booster swap from ZJ and Rusty’s SS braided brake lines
Cobra hand held CB with Wilson 3000 antenna
PostPosted: Thu Dec 24, 2015 7:35 pm
That's a very thorough answer!
Why 2 transfer cases?
Sent from my iPhone using Tapatalk
PostPosted: Thu Dec 24, 2015 7:44 pm
Vehicle: TJ
Lol
Sent from my SCH-I435 using Tapatalk
PostPosted: Thu Dec 24, 2015 8:13 pm
In case one fails of course.
It was just the description that I got from the guy I got it from. My apologies.
PostPosted: Thu Dec 24, 2015 9:00 pm
Cherokee sounds plenty set up, let's see how it works. Glad to have you along Mike.
PostPosted: Thu Dec 24, 2015 10:04 pm
I have no idea where the meet-up spot would be in case I did want to ride along. Any chance of getting that?
PostPosted: Thu Dec 24, 2015 10:08 pm
after bridge at y where carbon river road goes left and evans creek goes right up hill
PostPosted: Thu Dec 24, 2015 10:09 pm
Vehicle: 97 TJ 35's ARB locker warn 8274
Im in.
PostPosted: Thu Dec 24, 2015 10:15 pm
I think I found it. Sorry I'm new to off-roading in WA.
PostPosted: Thu Dec 24, 2015 10:20 pm
I'm Fun Sized!
Vehicle: 00 TJ
92 Cherokee
84 Yota
:thumbsup:
Lone Wolf Image
PostPosted: Thu Dec 24, 2015 11:13 pm
Vehicle: '97 XJ, some lift, some tires and some dirt (sold, currently jeep-less)
I'm in!
PostPosted: Fri Dec 25, 2015 8:21 am
Vehicle: TJ
We all were new at some point. Come out follow directions from the experience drivers and u will have a great time
PostPosted: Sat Dec 26, 2015 2:04 pm
Couldn't find a babysitter and wife didn't want me to go by myself. *sigh*
PostPosted: Mon Dec 28, 2015 9:20 pm
Vehicle: Spider Monkey
MrBaker wrote:
Model:
Engine:
Transmission:
Transfer Case:
Drive shafts
Front Axle:
Chromo shafts
Rear Axle:
Chromo Shafts
Raised shock mounts
Wheels/Tires:
Front Suspension
Rear Suspension:
Protection:
Stock gas tank skid
DPG Belly Pan
Front Bumper:
Rear Bumper:
Rock Sliders:
Cage:
Accessories:
I wrote that description probably more than 10 years ago!
I don't know of anyone else who would write a description like that ;)
It was a very capable wheeler and Very capable in the snow!
I am sure it has lots of changes but I hope it treats you well!
Michael
Michael
PostPosted: Wed Dec 30, 2015 7:41 pm
Vehicle: '69 Bronco
2xtreme wrote:
MrBaker wrote:
Model:
Engine:
blah blah blah....
Michael
I've said it once, I'll say it again; the hardcore Jeep world is a small and tight-knit one.
Baller
Nemo me impune lacessit.
